はじめに
Replace your faulty motherboard with a new one.
必要な工具と部品
Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
There will be two small clips on each side of the motherboard. Using the plastic opening tool unhook each clip one at a time
Once all four clips are unhooked you should be able to pull the motherboard from the casing using your hands.
After you remove the old motherboard, you can then replace it with a new one.
3 の人々がこのガイドを完成させました。
