メインコンテンツにスキップ
BlackBerry 7510 Logic Board Replacement
必要な工具と部品
  1. BlackBerry 7510 Logic Board Replacement, Back Face of Phone: 手順 1、 1の画像 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Logic Board Replacement: 手順 2、 1の画像 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Logic Board Replacement: 手順 3、 1の画像 1
    • Lift off the back cover.
  4. BlackBerry 7510 Logic Board Replacement: 手順 4、 1の画像 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Logic Board Replacement: 手順 5、 2の画像 1 BlackBerry 7510 Logic Board Replacement: 手順 5、 2の画像 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Logic Board Replacement, Logic Board: 手順 6、 1の画像 1
    • Using the T6 Torx screwdriver, remove the top screw.
  7. BlackBerry 7510 Logic Board Replacement: 手順 7、 1の画像 1
    • Using your spudger, carefully pry off back plate.
    • Use the same technique as with the plastic back cover. Circle around the back plate until all of it is pried up.
  8. BlackBerry 7510 Logic Board Replacement: 手順 8、 1の画像 1
    • Remove the front cover and keypad.
  9. BlackBerry 7510 Logic Board Replacement: 手順 9、 1の画像 1
    • Remove one T6 Torx screw in the front bottom right of the board.
  10. BlackBerry 7510 Logic Board Replacement: 手順 10、 2の画像 1 BlackBerry 7510 Logic Board Replacement: 手順 10、 2の画像 2
    • Carefully pry the screen from the board with your spudger.
    • After prying it up, remove the screen from the board.
  11. BlackBerry 7510 Logic Board Replacement: 手順 11、 2の画像 1 BlackBerry 7510 Logic Board Replacement: 手順 11、 2の画像 2
    • Unscrew center T6 Torx screw in the center of the logic board.
    • Remove the logic board from the phone.
    • Replace with new logic board.
終わりに
作成者
8人の作成者と共同で作成されました。
Neil Johnson
メンバー登録日: 01/24/10
12 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 14-44, Regan Winter 2010 Cal Poly, Team 14-44, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S14G44
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 3
今までの合計 1,849
