はじめに
This is a guide showing how to repair your keypad for the RIM blackberry 7510.
パーツ
パーツは必要ありません。
  1. Remove the battery cover and battery before continuing.
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. Using your finger nail or a spudger, carefully pry up the back cover.
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. Lift off the back cover.
    • Lift off the back cover.
  4. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  5. Remove the two T6 screws.
    • Remove the two T6 screws.
  6. Remove the daughterboard. Remove the exposed vibration motor.
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  7. Unscrew metal plate. Pry off front cover. Lift off front cover to expose LCD screen.
    • Unscrew metal plate.
    • Pry off front cover.
    • Lift off front cover to expose LCD screen.
  8. Remove keypad from front cover and replace or fix existing pad.
    • Remove keypad from front cover and replace or fix existing pad.
まとめ
Neil Johnson
メンバー登録日: 2010年01月24日
12 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 14-44, Regan Winter 2010 Cal Poly, Team 14-44, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S14G44
4 メンバー
8のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 2,459
