メインコンテンツにスキップ
BlackBerry 7290 LCD Replacement
必要な工具と部品
  1. BlackBerry 7290 LCD Replacement, Battery: 手順 1、 3の画像 1 BlackBerry 7290 LCD Replacement, Battery: 手順 1、 3の画像 2 BlackBerry 7290 LCD Replacement, Battery: 手順 1、 3の画像 3
    • Apply pressure to the lock button on the back of the device.
    • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
  2. BlackBerry 7290 LCD Replacement: 手順 2、 3の画像 1 BlackBerry 7290 LCD Replacement: 手順 2、 3の画像 2 BlackBerry 7290 LCD Replacement: 手順 2、 3の画像 3
    • Locate groove along the right side of the battery compartment.
    • Remove battery by prying between the battery and the groove.
  3. BlackBerry 7290 LCD Replacement, SIM Card: 手順 3、 1の画像 1
    • Slide the SIM card holder to the left to unlock the SIM card.
  4. BlackBerry 7290 LCD Replacement: 手順 4、 2の画像 1 BlackBerry 7290 LCD Replacement: 手順 4、 2の画像 2
    • Lift the SIM card holder up.
    • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
  5. BlackBerry 7290 LCD Replacement, Side Button: 手順 5、 1の画像 1
    • Locate the four screws along the perimeter of the back casing.
    • Remove the four top screws using a T-6 torx screwdriver.
    • The top four screws are .413 inches.
  6. BlackBerry 7290 LCD Replacement: 手順 6、 2の画像 1 BlackBerry 7290 LCD Replacement: 手順 6、 2の画像 2
    • Locate two screws within the lower edge of the inner compartment.
    • Remove the two bottom screws using a T-6 torx screwdriver.
    • The bottom two screws are .2 inches in length.
    • The second picture displays the device after the six screws have been removed.
  7. BlackBerry 7290 LCD Replacement: 手順 7、 1の画像 1
    • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
  8. BlackBerry 7290 LCD Replacement: 手順 8、 3の画像 1 BlackBerry 7290 LCD Replacement: 手順 8、 3の画像 2 BlackBerry 7290 LCD Replacement: 手順 8、 3の画像 3
    • Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
    • Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
  9. BlackBerry 7290 LCD Replacement: 手順 9、 2の画像 1 BlackBerry 7290 LCD Replacement: 手順 9、 2の画像 2
    • Locate on the backside of the phone, a screw towards the top of the device.
    • Using a T-6 screwdriver, remove the screw.
    • After the screw has been removed, carefully lift the side button brace to reveal the side button.
  10. BlackBerry 7290 LCD Replacement, Keypad: 手順 10、 1の画像 1
    • To remove the phone's internals, start by loosening one side by pulling gently.
  11. BlackBerry 7290 LCD Replacement: 手順 11、 1の画像 1
    • With one side loosened, simply lift the phone internals to separate from the front casing.
  12. BlackBerry 7290 LCD Replacement: 手順 12、 1の画像 1
    • Turn the internals over to reveal the LCD display.
  13. BlackBerry 7290 LCD Replacement: 手順 13、 2の画像 1 BlackBerry 7290 LCD Replacement: 手順 13、 2の画像 2
    • Peel off the rubber keypad buttons from the face plate.
  14. BlackBerry 7290 LCD Replacement, LCD: 手順 14、 1の画像 1
    • Locate a hook on the right side of the internals below the volume wheel.
    • Use a plastic opening tool to gently pry the hook, separating the LCD display from the logic board mounting plate.
  15. BlackBerry 7290 LCD Replacement: 手順 15、 2の画像 1 BlackBerry 7290 LCD Replacement: 手順 15、 2の画像 2
    • With the clip unhooked, gently separate the display from the phone internals by pulling.
終わりに
作成者
13人の作成者と共同で作成されました。
kmathew
メンバー登録日: 10/17/09
3 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 19-6, Maness Fall 2009 Cal Poly, Team 19-6, Maness Fall 2009人のメンバー
CPSU-MANESS-F09S19G6
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 5,933
