はじめに
手順 1 に進む ↓The battery connector connects the battery to the logic board. This part could be the cause of battery issues. This guide will demonstrate how to replace the battery connector after the logic board has been removed.
必要な工具と部品
ツール
With your thumb press down on the locking- button on the back of the BlackBerry 7280.
Slide the battery cover off the device.
Hold the device with both hands.
Lift the SIM card holder using your thumb and index finger.
Remove the SIM card from the device.
Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
Use the plastic opening tool to pry at the edge of the screen near the track-wheel.
To remove the battery connector simply slide it out from the metal bracket using your hand.
