この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide shows how to replace the BlackBerry 7100g external housing case.
必要な工具と部品
Turn over your BalckBerry 7100g so that the back cover is facing up.
Locate the battery cover release button near the bottom of the back panel.
Locate the silver strip near the top of your BlackBerry.
Use a plastic opening tool to pry off the edge of the silver lining.
Slide the tool along the length of the silver strip to completely remove it.
ある他の人がこのガイドを完成しました。
