メインコンテンツにスキップ
Black and Decker WP900 Motor Replacement
必要な工具と部品
  1. Black and Decker WP900 Motor Replacement, Motor: 手順 1、 1の画像 1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Motor Replacement: 手順 2、 1の画像 1
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Motor Replacement: 手順 3、 3の画像 1 Black and Decker WP900 Motor Replacement: 手順 3、 3の画像 2 Black and Decker WP900 Motor Replacement: 手順 3、 3の画像 3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Motor Replacement: 手順 4、 1の画像 1
    • Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Motor Replacement: 手順 5、 2の画像 1 Black and Decker WP900 Motor Replacement: 手順 5、 2の画像 2
    • Gently pull the power cord out from the control module.
    • Remember, when you're reassembling the device, the black wire should be on the top.
  6. Black and Decker WP900 Motor Replacement: 手順 6、 1の画像 1
    • Firmly grasping the motor, dislodge the internal components from the frontal external casing.
    • Switch and control panel are attached to the motor.
  7. Black and Decker WP900 Motor Replacement: 手順 7、 2の画像 1 Black and Decker WP900 Motor Replacement: 手順 7、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the two 22mm screws securing the brush assembly to the motor.
  8. Black and Decker WP900 Motor Replacement: 手順 8、 2の画像 1 Black and Decker WP900 Motor Replacement: 手順 8、 2の画像 2
    • To fully remove the brush assembly from the motor, push the brushes (enclosed in the gold ribbing) outward and pull up.
  9. Black and Decker WP900 Motor Replacement: 手順 9、 1の画像 1
    • With a large amount of force, pull the motor up and off of the wire coil.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Stefan Wolowec
メンバー登録日: 02/15/16
128 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 8-8, Wilson Spring 2016 IUPUI, Team 8-8, Wilson Spring 2016人のメンバー
IUPUI-WILSON-S16S8G8
4 メンバー
4のガイドは作成済み
コメント 1 件
Very straightforward tutotial. We are writing review of this product here https://www.helpful.reviews/en/product/4.... However we have not found many cases among owners of this product that they would need to repair motor by its replacement.
John Bazmek - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 19
今までの合計 2,267
