メインコンテンツにスキップ
Black and Decker Toast R Oven TRO405 Dissasembly
必要な工具と部品
  1. Black and Decker Toast R Oven TRO405 Dissasembly, Black and Decker Toast R Oven TRO405 Dissasembly: 手順 1、 2の画像 1 Black and Decker Toast R Oven TRO405 Dissasembly, Black and Decker Toast R Oven TRO405 Dissasembly: 手順 1、 2の画像 2
    • Make sure the toaster oven is unplugged before beginning.
    • You may want to clean out the worst of the spills in the toaster oven before beginning.
    • Open the toaster oven door and remove the shelf.
  2. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 2、 2の画像 1 Black and Decker Toast R Oven TRO405 Dissasembly: 手順 2、 2の画像 2
    • Turn the toaster upside down so that you are looking at the bottom of the toaster oven.
    • Use a 1/4 inch nut driver to remove the 15.7 mm screw on the dark brown plastic wire cover.
    • Take off the wire cover.
  3. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 3、 2の画像 1 Black and Decker Toast R Oven TRO405 Dissasembly: 手順 3、 2の画像 2
    • Still using the 1/4 inch nut driver, remove the pointy 19 mm screw on each white plastic side panel.
  4. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 4、 2の画像 1 Black and Decker Toast R Oven TRO405 Dissasembly: 手順 4、 2の画像 2
    • Once the screws are removed, take off the side panels by pulling them up and away from the toaster oven. It may take a little bit of wiggling to get them free.
  5. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 5、 1の画像 1
    • Remove the gray piece of metal on the bottom front (it will be on the top though because the toaster oven is upside down).
  6. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 6、 3の画像 1 Black and Decker Toast R Oven TRO405 Dissasembly: 手順 6、 3の画像 2 Black and Decker Toast R Oven TRO405 Dissasembly: 手順 6、 3の画像 3
    • Use the knob on the crumb tray to lift it up.
    • Slide the thin metal tab on the bottom of the tray out of the ring on the toaster oven.
  7. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 7、 2の画像 1 Black and Decker Toast R Oven TRO405 Dissasembly: 手順 7、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the two pointy 10 mm screws on both ends of the metal bar under the toaster oven door (currently on top because the device is upside down).
  8. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 8、 1の画像 1
    • Slide the metal bar (that you just removed the screws from) up to remove it.
  9. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 9、 3の画像 1 Black and Decker Toast R Oven TRO405 Dissasembly: 手順 9、 3の画像 2 Black and Decker Toast R Oven TRO405 Dissasembly: 手順 9、 3の画像 3
    • Using a 1/4 inch nut driver, remove the 10 mm screws on the back of the toaster oven.
    • Turn the toaster oven so it is right side up
  10. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 10、 1の画像 1
    • Grabbling the bottom of the piece of metal you just removed the screws from, lift that piece up until it comes away from the toaster oven.
  11. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 11、 1の画像 1
    • On the side of the toaster oven with the majority of the internal mechanisms, there is a spring. Remove the spring by unhooking each end from the toaster oven.
  12. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 12、 2の画像 1 Black and Decker Toast R Oven TRO405 Dissasembly: 手順 12、 2の画像 2
    • On the side of the door away from the controls, slide the tab away from the side of the toaster oven.
    • On the same side as the controls, slide the ring on the door along the wire that holds it to the toaster oven until it comes free.
  13. Black and Decker Toast R Oven TRO405 Dissasembly: 手順 13、 3の画像 1 Black and Decker Toast R Oven TRO405 Dissasembly: 手順 13、 3の画像 2 Black and Decker Toast R Oven TRO405 Dissasembly: 手順 13、 3の画像 3
    • Congratulations, you have successfully completed a teardown of a Black and Decker Toast R Oven TRO405.
    • There are some very cool internal mechanisms on the side of the toaster oven! We can't take them apart without causing permanent damage to the machine because they're all riveted together, but we encourage you to try to figure out how they work!
ゴール
添付文書
作成者
3人の作成者と共同で作成されました。
Caroline
メンバー登録日: 09/16/21
217 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 1,040
