Make sure that the toaster is unplugged before you begin.
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Remove the knobs by pulling them upward; they should slide right off.
When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
Unhook the bottom of the the display panel from the toaster unit.
It will be a little tough to pry off, but don't be afraid to be forceful. You can use your hands, or pliers, to bend the metal piece backwards.
Begin to detach the back panel from the toaster unit.
Then, unhook the rest of the display panel.
This will also be a little tough to get off, but don't be afraid to be forceful.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
