メインコンテンツにスキップ
はじめに
In order to replace to On/Off switch, you will once again have to take apart the whole unit to get to that part.
パーツ
パーツは指定されていません。
  1. Make sure that the toaster is unplugged before you begin.
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster over with its backside face down.
    • Remove the two Phillips #4 1cm screws that attach the side panels.
  2. Pull downwards (towards the bottom of the unit) and outward to remove the side panels. Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
    • Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
  3. Remove the metal vent piece that is below the door.
    • Remove the metal vent piece that is below the door.
    • This should slide off easily once both of the side panels are removed.
  4. Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
    • Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
  5. Remove the crumb tray (the bottom, metal panel) from the toaster unit.
    • Remove the crumb tray (the bottom, metal panel) from the toaster unit.
  6. Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
    • Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
  7. Remove the knobs by pulling them upward; they should slide right off.
    • Remove the knobs by pulling them upward; they should slide right off.
    • When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
  8. Unhook the bottom of the the display panel from the toaster unit.
    • Unhook the bottom of the the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful. You can use your hands, or pliers, to bend the metal piece backwards.
  9. Begin to detach the back panel from the toaster unit.
    • Begin to detach the back panel from the toaster unit.
    • Then, unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
  10. Now, you can clean the outside units of the toaster oven.
    • Now, you can clean the outside units of the toaster oven.
  11. Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
    • Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
  12. Finish removing the outside cover by lifting the lid upward.
    • Finish removing the outside cover by lifting the lid upward.
  13. Remove the four Phillips #4 1 cm screws from the back of the unit.
    • Remove the four Phillips #4 1 cm screws from the back of the unit.
  14. Remove the two Phillips #4 1 cm screws that were under the faceplate.
    • Remove the two Phillips #4 1 cm screws that were under the faceplate.
  15. Forcefully bend back the faceplate in order to get to the knob. Forcefully bend back the faceplate in order to get to the knob.
    • Forcefully bend back the faceplate in order to get to the knob.
  16. Remove pin holding the On/Off switch in place.
    • Remove pin holding the On/Off switch in place.
  17. Remove switch from the opening it protrudes from.
    • Remove switch from the opening it protrudes from.
    • This will take a little bit of manipulating but it will come out.
終わりに
To reassemble your device, follow these instructions in reverse order. It will look like the faceplate is still bent out, but after you put the screws back in it will come back into place.
2 の人々がこのガイドを完成させました。
Jonathan
メンバー登録日: 2012年09月18日
245 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 2-10, Propen Fall 2012 Cal Poly, Team 2-10, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S2G10
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 45
今までの合計 7,454
