はじめに
If the toaster door does not stay shut, heat will escape and the toaster will not work properly. This problem can be solved by simply replacing the door spring mechanism.
必要なもの
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Use the screwdriver to remove the spring from the unit.
Place the screwdriver inside the spring loop.
Pull to unhinge the spring from the back panel.
2 の人々がこのガイドを完成させました。
2 件のコメント
Great guide! Very clearly-written and accompanying photos captured the process effectively.
Mo Poppins - 返信
