この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Learn how to manipulate your Black and Decker Toast R Oven in order to clean it, to replace its door-spring mechanism, and/or to replace its damaged door.
必要な工具と部品
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Use the screwdriver to remove the spring from the unit.
Place the screwdriver inside the spring loop.
Pull to unhinge the spring from the back panel.
4 の人々がこのガイドを完成させました。
2 件のコメント
sale humo al momento de prender el horno
