メインコンテンツにスキップ
Black and Decker TR1278B Lever Catch-Spring Replacement
必要な工具と部品
  1. Black and Decker TR1278B Lever Catch-Spring Replacement, Top Cover: 手順 1、 1の画像 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Lever Catch-Spring Replacement: 手順 2、 1の画像 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Lever Catch-Spring Replacement: 手順 3、 1の画像 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Lever Catch-Spring Replacement: 手順 4、 1の画像 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Lever Catch-Spring Replacement: 手順 5、 1の画像 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. Black and Decker TR1278B Lever Catch-Spring Replacement, Lever Catch Spring: 手順 6、 1の画像 1
    • Lift the top cover up and remove it from the toaster.
  7. Black and Decker TR1278B Lever Catch-Spring Replacement: 手順 7、 1の画像 1
    • Locate the springs.
    • There is a top spring and bottom spring.
  8. Black and Decker TR1278B Lever Catch-Spring Replacement: 手順 8、 2の画像 1 Black and Decker TR1278B Lever Catch-Spring Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use needle nose tweezers to free one end of the spring.
    • Turn the spring until it is completely free.
  9. Black and Decker TR1278B Lever Catch-Spring Replacement: 手順 9、 1の画像 1
    • Remove spring for replacement.
    • Repeat steps for bottom spring.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Brea-Monique
メンバー登録日: 02/15/17
351 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 8-1, Eyestone Spring 2017 USF Tampa, Team 8-1, Eyestone Spring 2017人のメンバー
USFT-EYESTONE-S17S8G1
3 メンバー
5のガイドは作成済み
コメント 1 件
Hi there, thanks for this guide. I have a little issue : one of the screws is quite unusual, probably because it’s not meant to be repaired by a poor peasant. It has a little pin in it and I can’t unscrew it with the tools I have. Any tips ?
ToasterMaster - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 30
今までの合計 1,325
