メインコンテンツにスキップ
Black and Decker TR1278B Bread Grabber Spring Replacement
必要な工具と部品
  1. Black and Decker TR1278B Bread Grabber Spring Replacement, Top Cover: 手順 1、 1の画像 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Bread Grabber Spring Replacement: 手順 2、 1の画像 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Bread Grabber Spring Replacement: 手順 3、 1の画像 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Bread Grabber Spring Replacement: 手順 4、 1の画像 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Bread Grabber Spring Replacement: 手順 5、 1の画像 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. Black and Decker TR1278B Bread Grabber Spring Replacement, Bread Grabber Spring: 手順 6、 1の画像 1
    • Locate the spring
  7. Black and Decker TR1278B Bread Grabber Spring Replacement: 手順 7、 1の画像 1
    • Press down on the toaster lever to gain access to the grabber spring located behind the large metal plate.
    • Use metal spudger to loosen clamps on spring.
  8. Black and Decker TR1278B Bread Grabber Spring Replacement: 手順 8、 1の画像 1
    • Use needle nose tweezers to pull the spring off of its hook.
    • Repeat this step for the opposite side.
  9. Black and Decker TR1278B Bread Grabber Spring Replacement: 手順 9、 1の画像 1
    • Remove the old spring from the toaster unit to insert the new one.
終わりに
作成者
3人の作成者と共同で作成されました。
Brea-Monique
メンバー登録日: 02/15/17
351 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 8-1, Eyestone Spring 2017 USF Tampa, Team 8-1, Eyestone Spring 2017人のメンバー
USFT-EYESTONE-S17S8G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 24
今までの合計 1,201
