メインコンテンツにスキップ
Black and Decker Pivot Plus PD600 Motor Replacement
必要な工具と部品
  1. Black and Decker Pivot Plus PD600 Motor Replacement, Drill: 手順 1、 3の画像 1 Black and Decker Pivot Plus PD600 Motor Replacement, Drill: 手順 1、 3の画像 2 Black and Decker Pivot Plus PD600 Motor Replacement, Drill: 手順 1、 3の画像 3
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. Black and Decker Pivot Plus PD600 Motor Replacement: 手順 2、 1の画像 1
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  3. Black and Decker Pivot Plus PD600 Motor Replacement, Motor: 手順 3、 1の画像 1
    • After opening the the casing, locate and grab the head of the drill. Twist the motor counter-clockwise and pull to detach it from the transmission.
    • However, do not pull too hard because the motor is attached to other components of the drill by wires.
  4. Black and Decker Pivot Plus PD600 Motor Replacement: 手順 4、 2の画像 1 Black and Decker Pivot Plus PD600 Motor Replacement: 手順 4、 2の画像 2
    • After taking out the motor, you can observe two wires that are plugged in (or possibly soldered, depending on which variant you have) to the bottom of the motor. To detach the motor, unplug the wires or desolder their connections with a soldering iron as needed.
    • Mark or color code the black and red wires so you can return them to the correct position.
  5. Black and Decker Pivot Plus PD600 Motor Replacement: 手順 5、 1の画像 1
    • Wait for the wires and connectors to cool. Pull the wires from the motor and the motor should now be fully disconnected from the drill.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Jonathon Centofranchi
メンバー登録日: 04/19/13
307 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-15, Maness Spring 2013 Cal Poly, Team 4-15, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S4G15
5 メンバー
6のガイドは作成済み
コメント 1 件
If my motor try to turn is there anything I can do to fix-it? :)
Kenny Ray Carder - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 15
今までの合計 1,318
