メインコンテンツにスキップ
Black and Decker Pivot Plus PD600 Circuit Board Replacement
必要な工具と部品
  1. Black and Decker Pivot Plus PD600 Circuit Board Replacement, Drill: 手順 1、 3の画像 1 Black and Decker Pivot Plus PD600 Circuit Board Replacement, Drill: 手順 1、 3の画像 2 Black and Decker Pivot Plus PD600 Circuit Board Replacement, Drill: 手順 1、 3の画像 3
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. Black and Decker Pivot Plus PD600 Circuit Board Replacement: 手順 2、 1の画像 1
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  3. Black and Decker Pivot Plus PD600 Circuit Board Replacement, Circuit Board: 手順 3、 1の画像 1
    • Carefully grip the circuit board on the exposed edge and lift it away from the drill as far as is possible.
    • Make note of where each wire connects on the circuit board.
  4. Black and Decker Pivot Plus PD600 Circuit Board Replacement: 手順 4、 2の画像 1 Black and Decker Pivot Plus PD600 Circuit Board Replacement: 手順 4、 2の画像 2
    • Starting from the most accessible wire, desolder the wires from the circuit board one by one.
    • Make sure that the tip of the soldering iron is clean of all residue before starting.
    • Heat the soldering iron only to the temperature required to melt the solder. Check the specifications on your spool of solder for the correct temperature.
    • Once all of the wires have been desoldered from the circuit board, remove the circuit board completely from the drill.
終わりに
作成者
6人の作成者と共同で作成されました。
Mason Garcia
メンバー登録日: 04/19/13
39 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 4-15, Maness Spring 2013 Cal Poly, Team 4-15, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S4G15
5 メンバー
6のガイドは作成済み
コメント 1 件
It’s important to note the *color of the wires as they are de-soldered, and their *locations on the *circuit board, in order to re-solder them in the correct location as you re-assemble your drill-driver. (Not everyone has a long-term, photographic memory) I found this to be very important as I was interrupted during my repair and could not return for 1 or 2 days to complete it.
maddogsmith2003 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 1,134
