はじめに
If your drill stops working and the battery stops holding a charge chances are you need a new battery. You can find a replacement parts including the battery under the replacement part links in the device page. This guide will show you how to install this new battery.
必要な工具と部品
Locate the battery and remove it from its slot at the end of the drill opposite the motor. It should be at the butt of the drill by the handle.
9 の人々がこのガイドを完成させました。
9 件のコメント
this drill adapter, why "6V" and the adapter body is marked 9VAC output? which is true output?
Can someone test the output and tell me the voltage? VDC? VAC? thankyou.
B+D sell the replacement for ~$17
Unfortunately I do not own the drill anymore so I can't test its output. I do know that the battery used is 6V, so I would assume that is the output. Hopes this helps!
