メインコンテンツにスキップ
Black and Decker PS1800 Transmission Replacement
必要な工具と部品
  1. Black and Decker PS1800 Transmission Replacement, Open the Outer Drill Case: 手順 1、 2の画像 1 Black and Decker PS1800 Transmission Replacement, Open the Outer Drill Case: 手順 1、 2の画像 2
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800 Transmission Replacement: 手順 2、 1の画像 1
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800 Transmission Replacement, Disconnect Motor: 手順 3、 3の画像 1 Black and Decker PS1800 Transmission Replacement, Disconnect Motor: 手順 3、 3の画像 2 Black and Decker PS1800 Transmission Replacement, Disconnect Motor: 手順 3、 3の画像 3
    • Locate the motor at the top left hand corner.
    • Carefully disconnect the red and black wires attached to the motor.
  4. Black and Decker PS1800 Transmission Replacement: 手順 4、 1の画像 1
    • Unscrew the motor from the drill's transmission.
    • Detach the transmission carefully, ensuring that the gears remain intact.
  5. Black and Decker PS1800 Transmission Replacement: 手順 5、 2の画像 1 Black and Decker PS1800 Transmission Replacement: 手順 5、 2の画像 2
    • Remove the motor from the transmission assembly, as pictured.
  6. Black and Decker PS1800 Transmission Replacement, Transmission: 手順 6、 3の画像 1 Black and Decker PS1800 Transmission Replacement, Transmission: 手順 6、 3の画像 2 Black and Decker PS1800 Transmission Replacement, Transmission: 手順 6、 3の画像 3
    • Unscrew the torque adjuster from the transmission by removing the screws highlighted in the lefthand picture.
  7. Black and Decker PS1800 Transmission Replacement: 手順 7、 1の画像 1
    • Align the new transmission gears with the motor’s gears.
    • Reattach the transmission and motor by rescrewing the initial screws.
  8. Black and Decker PS1800 Transmission Replacement: 手順 8、 2の画像 1 Black and Decker PS1800 Transmission Replacement: 手順 8、 2の画像 2
    • Reconnect the torque adjuster to the transmission by following the procedure seen in step 6.
  9. Black and Decker PS1800 Transmission Replacement: 手順 9、 1の画像 1
    • Reconnect black and red wires onto the motor and place the motor, transmission and torque adjuster back onto their initial location.
  10. Black and Decker PS1800 Transmission Replacement: 手順 10、 1の画像 1
    • Reconnect the clamshell.
    • Press trigger to make sure the new transmission works.
    • Press and hold the clam-shell to assure it will not drop while testing.
終わりに
作成者
9人の作成者と共同で作成されました。
David Nawl
メンバー登録日: 10/19/16
279 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 2-3, Baechle Fall 2016 IUPUI, Team 2-3, Baechle Fall 2016人のメンバー
IUPUI-BAECHLE-F16S2G3
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 15
今までの合計 1,480
