はじめに
This guide will show how to replace the transmission of Black and Decker PS-1800.
必要な工具と部品
Lay the drill on its side, assuring that the screw holes are facing upwards.
Remove seven 12 mm screws using a Phillips #00 screwdriver.
Locate the motor at the top left hand corner.
Carefully disconnect the red and black wires attached to the motor.
Unscrew the torque adjuster from the transmission by removing the screws highlighted in the lefthand picture.
もう少しです!
終わりに
