メインコンテンツにスキップ
Black and Decker LI4000 Outer Casing Replacement
必要な工具と部品
  1. Black and Decker LI4000 Outer Casing Replacement, Outer Casing: 手順 1、 3の画像 1 Black and Decker LI4000 Outer Casing Replacement, Outer Casing: 手順 1、 3の画像 2 Black and Decker LI4000 Outer Casing Replacement, Outer Casing: 手順 1、 3の画像 3
    • Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
  2. Black and Decker LI4000 Outer Casing Replacement: 手順 2、 1の画像 1
    • Remove all six of the 12-mm long case screws with a Philips #1 Screwdriver. These screws can be found on the side of the LI4000 with the "Warning" sticker.
  3. Black and Decker LI4000 Outer Casing Replacement: 手順 3、 2の画像 1 Black and Decker LI4000 Outer Casing Replacement: 手順 3、 2の画像 2
    • Remove the two screws that are 4-mm Hexagonal #2.5. These are very small case screws that can be found underneath the two stickers from Step 1.
  4. Black and Decker LI4000 Outer Casing Replacement: 手順 4、 2の画像 1 Black and Decker LI4000 Outer Casing Replacement: 手順 4、 2の画像 2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry on the seam as shown with a Spudger, in order to get the top casing loose.
    • Pull the two sides apart while making sure the side that you are removing is the one with all of the case screw holes.
    • It is good practice to remove the top connection of the battery as shown in the third image, as this will be the first step to replacing any of the components for this screwdriver.
終わりに
作成者
2人の作成者と共同で作成されました。
Bryan Beard
メンバー登録日: 02/11/16
107 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 2-3, Baechle Spring 2016 IUPUI, Team 2-3, Baechle Spring 2016人のメンバー
IUPUI-BAECHLE-S16S2G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 24
今までの合計 336
