はじめに
This guide will walk you through the steps to replace a faulty trigger switch in a Black and Decker LDX172C cordless drill. Steps one through three will walk you through the disassembly process and step four will walk you through the process of removing and replacing the trigger switch. Tools necessary for this operation include a Philips screw driver set and a soldering work station. Approximate repair time is 40 minutes.
必要な工具と部品
Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
