メインコンテンツにスキップ
Black and Decker LDX172C LED Power Indicator Replacement
必要な工具と部品
  1. Black and Decker LDX172C LED Power Indicator Replacement, LED Power Indicator: 手順 1、 1の画像 1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C LED Power Indicator Replacement: 手順 2、 1の画像 1
    • Rotate the drill to it's left side - the chuck should be facing rightward. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C LED Power Indicator Replacement: 手順 3、 1の画像 1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the LED power indicator located just above the battery pack.
  4. Black and Decker LDX172C LED Power Indicator Replacement: 手順 4、 2の画像 1 Black and Decker LDX172C LED Power Indicator Replacement: 手順 4、 2の画像 2
    • The LED is located on a small surface mount circuit board that easily slides out of its mounting location.
    • The LED is removed by freeing the solder joints on the bottom side of the circuit board.
    • Place the new LED through the same holes and re-solder it.
    • To reassemble repeat directions in reverse order.
終わりに
作成者
4人の作成者と共同で作成されました。
Casey
メンバー登録日: 02/13/16
260 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 3-3, Wilson Spring 2016 IUPUI, Team 3-3, Wilson Spring 2016人のメンバー
IUPUI-WILSON-S16S3G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 13
今までの合計 205
