メインコンテンツにスキップ
Black and Decker LDX172C Battery Charge Port Replacement
必要な工具と部品
  1. Black and Decker LDX172C Battery Charge Port Replacement, Battery Charge Port: 手順 1、 1の画像 1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Battery Charge Port Replacement: 手順 2、 1の画像 1
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Battery Charge Port Replacement: 手順 3、 1の画像 1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the battery charging port in the base of the drill.
  4. Black and Decker LDX172C Battery Charge Port Replacement: 手順 4、 1の画像 1
    • Remember that the battery may still have a charge. To avoid electrical shock, it is a good idea to disconnect the battery before modifying any connections on the charging port. You can find how to disconnect the battery here
    • Remove the soldered wire connections as marked.
    • Re-solder the wire connections to the new charge port and insert the charge port back into its proper location.
    • Repeat steps in reverse to reassemble.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Eric Miessen
メンバー登録日: 02/13/16
182 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 3-3, Wilson Spring 2016 IUPUI, Team 3-3, Wilson Spring 2016人のメンバー
IUPUI-WILSON-S16S3G3
4 メンバー
6のガイドは作成済み
コメント 1 件
Hi where can I get the replacement charge port from. Thanks
adam mellor - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 29
今までの合計 2,533
