メインコンテンツにスキップ
Black and Decker LDX 120C Chuck Replacement
必要な工具と部品
  1. Black and Decker LDX 120C Chuck Replacement, Outer Case: 手順 1、 1の画像 1
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Black and Decker LDX 120C Chuck Replacement: 手順 2、 1の画像 1
    • Remove the four screws on the back top side of the drill.
  3. Black and Decker LDX 120C Chuck Replacement: 手順 3、 1の画像 1
    • Remove the four screws that connect the chuck to the drill.
  4. Black and Decker LDX 120C Chuck Replacement: 手順 4、 1の画像 1
    • Remove the five screws on the front side of the drill.
  5. Black and Decker LDX 120C Chuck Replacement: 手順 5、 1の画像 1
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. Black and Decker LDX 120C Chuck Replacement: 手順 6、 1の画像 1
    • At this point you should be able to separate both as illustrated.
  7. Black and Decker LDX 120C Chuck Replacement: 手順 7、 1の画像 1
    • Now all the components of the drill are visible and can be accessed.
  8. Black and Decker LDX 120C Chuck Replacement, Chuck: 手順 8、 1の画像 1
    • After following the prerequisite, the drill is now open.
    • The interior components can now be accessed.
  9. Black and Decker LDX 120C Chuck Replacement: 手順 9、 1の画像 1
    • Separate the top part(the chuck and motor) from the rest of the drill.
  10. Black and Decker LDX 120C Chuck Replacement: 手順 10、 1の画像 1
    • While separating the top from the rest, do this carefully without over stretching the wires so that no connection is damaged.
  11. Black and Decker LDX 120C Chuck Replacement: 手順 11、 1の画像 1
    • To remove the motor simply twist as illustrated in the picture.
  12. Black and Decker LDX 120C Chuck Replacement: 手順 12、 1の画像 1
    • The three metal tips in the front are the ones that are controlled by the chuck to hold and release the screw.
  13. Black and Decker LDX 120C Chuck Replacement: 手順 13、 1の画像 1
    • To test the chuck twist the head as shown in the illustration.
    • If the three metal tips don't move upon twisting then the chuck isn't working effectively and will need to be replaced since the inside of the chuck can't be accessed.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
jeffrey zakka
メンバー登録日: 02/09/16
735 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 11-5, Cheng Spring 2016 USF Tampa, Team 11-5, Cheng Spring 2016人のメンバー
USFT-CHENG-S16S11G5
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 36
今までの合計 2,741
