はじめに
If the saw has a broken shoe plate, this guide will show you how to replace it. It is simply two screws that must be removed in order to remove the entire plate.
必要な工具と部品
Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
Remove the 6.3mm hex screw on the left with a H.30 hex screwdriver.
Remove the reverse threaded 6.9mm black hex screw on the right with a H.40 hex screwdriver.
2 の人々がこのガイドを完成させました。
