メインコンテンツにスキップ
Black and Decker FT1000 Type 1 Blower Switch Replacement
必要な工具と部品
  1. Black and Decker FT1000 Type 1 Blower Switch Replacement, Black and Decker FT1000 Blower: 手順 1、 2の画像 1 Black and Decker FT1000 Type 1 Blower Switch Replacement, Black and Decker FT1000 Blower: 手順 1、 2の画像 2
    • This is the blower. I have removed the nozzle and strap.
  2. Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 2、 1の画像 1
    • Remove Screws.
  3. Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 3、 1の画像 1
    • Remove rear cover. It helps to hold the plug tight to the front housing so the wires stay in place.
  4. Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 4、 3の画像 1 Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 4、 3の画像 2 Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 4、 3の画像 3
    • Notice the switch is fine, it's simply the plastic armature that is broken.
    • The broken piece is only included with the motor and switch.
  5. Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 5、 1の画像 1
    • This switch is easy to find. It's just a single position single throw switch.
    • I was able to buy it at a home improvement store for $4.00.
    • It even fits nicely in the cutout for the original switch/armature.
  6. Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 6、 3の画像 1 Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 6、 3の画像 2 Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 6、 3の画像 3
    • Remove the switch/armature.
    • Remove the tension plate (the metal piece).
    • Put in the switch. The terminals are at a bad angle, so we will bend them to fit.
  7. Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 7、 2の画像 1 Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 7、 2の画像 2
    • Bend slowly and carefully.
    • Try it in and see how well it fits. It might need some tweaking.
  8. Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 8、 2の画像 1 Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 8、 2の画像 2
    • Now remove the actual electrical switch. No need to worry about the wiring, its just open and closed.
  9. Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 9、 1の画像 1
    • The black wire gets a new wider terminal and just plugs on.
    • The other wire needs to be a bit longer, so it gets an extension and a new terminal.
    • I used simple crimp on terminals and splice.
  10. Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 10、 2の画像 1 Black and Decker FT1000 Type 1 Blower Switch Replacement: 手順 10、 2の画像 2
    • There was not enough room for the terminal to pass by the plastic housing. I just removed a little and then routed the black wire under the switch.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Scot Henderson
メンバー登録日: 05/18/15
857 ポイント
2のガイドは作成済み
5件のガイドコメント
This works great. Thank you.
JFGuerrero - 返信
Scot,
Thanks so much for your excellent information!!! The exact same part broke on mine today. I looked at your outstanding detail on what to do. I looked through my stash of stuff and found a toggle switch just like the one you showed but from a different manufacturer. I just got done putting it in as you described and it is better than new now. Works like a champ!
Thanks so much,
John Brodrecht
Casper, WY
John Brodrecht - 返信
This was an excellent post with the perfect amount of detail and clear pictures!
I only wish you had the wiring part in the same detail because I think my wiring is faulty. I will look for your posts again for guidance. Thanks
Julie - 返信
Thank you for the excellent tutorial! I used the same switch and followed your diagrams and the blower is back up and running. The only thing I did differently is to remove a little bit of the orange plastic housing just forward of where the two wires come in under the switch. I had success with anX-Acto knife and a Dremel tool.
Mark Challgren - 返信
I am looking for a replacement motor or an amature for these model FT1000 or BL 950 ( same design) psadafal@rogers.com
Parasram Sadafal - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 34
今までの合計 3,703
