はじめに
This guide will take you through the process of replacing the power cord on the Black and Decker BV2500 Type 4. Without a power cord that works, the device will not turn on.
  1. Locate and unscrew the six 20 mm Phillips #2 screws in the black plastic casing (clamshell) with a Phillips #2 screwdriver.
    • Locate and unscrew the six 20 mm Phillips #2 screws in the black plastic casing (clamshell) with a Phillips #2 screwdriver.
  2. Using your hands, remove the blower tube and clamshell. To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
    • Using your hands, remove the blower tube and clamshell.
      • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver. Use your hands to lift off the side of the orange casing with the screws facing you.
    • Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver.
    • Use your hands to lift off the side of the orange casing with the screws facing you.
  5. Locate the switch. Remove the 2 black and white wires with blue casings from the switch.
    • Locate the switch.
    • Remove the 2 black and white wires with blue casings from the switch.
      • Using your hands, push in the sides of the switch and slide out the wires.
  6. Unscrew the two 20 mm Phillips #2 screws that are holding in the power cord (located at the bottom of the leaf hog) with a Phillips #2 screwdriver.
    • Unscrew the two 20 mm Phillips #2 screws that are holding in the power cord (located at the bottom of the leaf hog) with a Phillips #2 screwdriver.
  7. Slide the power cord support off the power cord in the direction of the leads. Use your hands to pull the power cord out of the device with the lead end coming out last. Use your hands to pull the power cord out of the device with the lead end coming out last.
    • Slide the power cord support off the power cord in the direction of the leads.
    • Use your hands to pull the power cord out of the device with the lead end coming out last.
まとめ
Angelica Chow
メンバー登録日: 2014年01月25日
363 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 9-29, Maness Winter 2014 Cal Poly, Team 9-29, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S9G29
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 1,565
