はじめに
Upon completion of this guide, you can successfully install and replace the motor fan for you blender.
  1. Before disassembling the blender base, make sure the blender disconnected from any power outlet. Lift the jar straight up from the base without tilting the jar.
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver. This provides access to the base screws beneath.
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Remove the following screws that secure the top and  bottom halves of the base.
    • Remove the following screws that secure the top and bottom halves of the base.
      • One 1/4 Phillips screw
      • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  6. Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  7. Using pliers, remove the top nut from the fan and remove the washer. Use a small towel to hold the fan in place. This makes taking off the nut easier to do.
    • Using pliers, remove the top nut from the fan and remove the washer.
    • Use a small towel to hold the fan in place. This makes taking off the nut easier to do.
  8. Lift the fan blades from the blender base.
    • Lift the fan blades from the blender base.
まとめ
2 の人々がこのガイドを完成させました。
Andrew
メンバー登録日: 2012年10月04日
170 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S6G34
4 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 31
今までの合計 2,694
