はじめに
The motor within the Black and Decker BDH9600CHV could fail. If that happens this guide will show you how to take the housing apart and extract the motor from the device. After extracting the motor from the device the replacement motor must then be inserted into the device and then the device closed back together.
If the device doesn't work after this, simply take the motor and insert the prongs on the opposite sides that they are inserted into on the circuit board.
必要な工具と部品
もう少しです!
終わりに
