はじめに
This guide provides information on how to remove and replace the Power Cord of the BLACK and DECKER BDERO100 5 inch sander. The tools that you will need for this process is the JIS - J1 bit driver or equivalent, the TR20 Torx Security bit driver or equivalent, the plastic spudger & the plastic opening tool.
必要な工具と部品
Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
ある他の人がこのガイドを完成しました。
