メインコンテンツにスキップ
Black and Decker BDERO100 Holder Brush and Spring Replacement
必要な工具と部品
  1. Black and Decker BDERO100 Holder Brush and Spring Replacement, Chassis: 手順 1、 2の画像 1 Black and Decker BDERO100 Holder Brush and Spring Replacement, Chassis: 手順 1、 2の画像 2
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 2、 2の画像 1 Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 2、 2の画像 2
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 3、 2の画像 1 Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 3、 2の画像 2
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 4、 2の画像 1 Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 4、 2の画像 2
    • Hold the chassis and separate it from the device.
  5. Black and Decker BDERO100 Holder Brush and Spring Replacement, Holder Brush and Spring: 手順 5、 3の画像 1 Black and Decker BDERO100 Holder Brush and Spring Replacement, Holder Brush and Spring: 手順 5、 3の画像 2 Black and Decker BDERO100 Holder Brush and Spring Replacement, Holder Brush and Spring: 手順 5、 3の画像 3
    • Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
  6. Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 6、 2の画像 1 Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 6、 2の画像 2
    • With yout hands, hold and separate the power button from the external case by pulling gently.
  7. Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 7、 1の画像 1
    • Identify the white cables connected to the holder brush and spring.
  8. Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 8、 2の画像 1 Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 8、 2の画像 2
    • Hold the motor and gently pull to remove from chassis.
  9. Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 9、 3の画像 1 Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 9、 3の画像 2 Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 9、 3の画像 3
    • Remove the wire connected to the brush holder from the motor by pulling gently.
  10. Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 10、 3の画像 1 Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 10、 3の画像 2 Black and Decker BDERO100 Holder Brush and Spring Replacement: 手順 10、 3の画像 3
    • Make a note of where each wire should be, you will avoid making wiring mistakes when assembling the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Irene Zubillaga
メンバー登録日: 02/10/16
617 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-5, Sullivan Spring 2016 USF Tampa, Team 1-5, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S1G5
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 1,642
