メインコンテンツにスキップ
Black and Decker BDEDMT Power Cord Replacement
必要な工具と部品
  1. Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: 手順 1、 2の画像 1 Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: 手順 1、 2の画像 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: 手順 2、 3の画像 1 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: 手順 2、 3の画像 2 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: 手順 2、 3の画像 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: 手順 3、 2の画像 1 Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: 手順 3、 2の画像 2
    • Using the T-handle screwdriver with the JIS 1 bit, unscrew the two lower black 12mm screws.
  4. Black and Decker BDEDMT Power Cord Replacement: 手順 4、 2の画像 1 Black and Decker BDEDMT Power Cord Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  5. Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: 手順 5、 2の画像 1 Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: 手順 5、 2の画像 2
    • Physically pull up on the trigger device and remove it from the armature.
    • Flip trigger device over onto its back.
  6. Black and Decker BDEDMT Power Cord Replacement, Wire Removal: 手順 6、 3の画像 1 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: 手順 6、 3の画像 2 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: 手順 6、 3の画像 3
    • There is a screw labeled 3 located on the bottom left of the back of the trigger device.
    • Use a JIS 0 screwdriver to remove screw.
    • Gently tug on the black wire to pull the wire out of the device.
    • Now the power cord will be completely removed from the device.
終わりに
作成者
8人の作成者と共同で作成されました。
cayla dahl
メンバー登録日: 02/01/16
247 ポイント
2のガイドは作成済み
チーム
UW Tacoma, Team 1-2, Rose Winter 2016 UW Tacoma, Team 1-2, Rose Winter 2016人のメンバー
UWT-ROSE-W16S1G2
4 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 45
今までの合計 2,789
