メインコンテンツにスキップ
Black and Decker BDEDMT Motor Replacement
必要な工具と部品
  1. Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: 手順 1、 2の画像 1 Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: 手順 1、 2の画像 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: 手順 2、 3の画像 1 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: 手順 2、 3の画像 2 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: 手順 2、 3の画像 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Motor Replacement, Motor: 手順 3、 1の画像 1
    • Gently pull up the motor and other components at the top of the device except the handle.
    • Watch out for the wires. They are connected to two compressed magnets in the black framework.
  4. Black and Decker BDEDMT Motor Replacement: 手順 4、 2の画像 1 Black and Decker BDEDMT Motor Replacement: 手順 4、 2の画像 2
    • Slide off the the black framework on the barring side.
    • You may have to compress the magnets in order to slide the framework off of the barring.
  5. Black and Decker BDEDMT Motor Replacement: 手順 5、 2の画像 1 Black and Decker BDEDMT Motor Replacement: 手順 5、 2の画像 2
    • Remove the release button attached at the front of the motor.
    • It may have already come off during Step 3.
  6. Black and Decker BDEDMT Motor Replacement: 手順 6、 2の画像 1 Black and Decker BDEDMT Motor Replacement: 手順 6、 2の画像 2
    • Work the silver magnetic ring off of the motor through the barring end.
    • The motor is now free.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Tyler Yurina
メンバー登録日: 02/01/16
419 ポイント
2のガイドは作成済み
チーム
UW Tacoma, Team 1-2, Rose Winter 2016 UW Tacoma, Team 1-2, Rose Winter 2016人のメンバー
UWT-ROSE-W16S1G2
4 メンバー
11のガイドは作成済み
3 件のコメント
Hi,
Please can you tell me where to find the motor replacement part for this tool?
Thank you
Renato - 返信
I have this tool and the attachments and I absolutely love it…but I'm pretty sure the gears are stripped…do you know anything about replacing those?
cwilson0713@gmail.com - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 61
今までの合計 2,654
