メインコンテンツにスキップ
Black and Decker BDEDMT Directional Switch Replacement
必要な工具と部品
  1. Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: 手順 1、 2の画像 1 Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: 手順 1、 2の画像 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: 手順 2、 3の画像 1 Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: 手順 2、 3の画像 2 Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: 手順 2、 3の画像 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: 手順 3、 2の画像 1 Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: 手順 3、 2の画像 2
    • Gently pull up on the trigger module.
    • Be sure to not loosen or disturb any wiring.
  4. Black and Decker BDEDMT Directional Switch Replacement: 手順 4、 2の画像 1 Black and Decker BDEDMT Directional Switch Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • With the trigger module out of the way you will then remove the metal piece that is located behind the directional switch and has the spring attached to it.
    • Do this by simply pulling up on the metal with your fingers or your tweezers.
    • Make sure to not loosen or remove the black trigger stopper.
  5. Black and Decker BDEDMT Directional Switch Replacement: 手順 5、 2の画像 1 Black and Decker BDEDMT Directional Switch Replacement: 手順 5、 2の画像 2
    • The black directional switch can now be freely removed.
終わりに
作成者
3人の作成者と共同で作成されました。
Tyler Yurina
メンバー登録日: 02/01/16
419 ポイント
2のガイドは作成済み
チーム
UW Tacoma, Team 1-2, Rose Winter 2016 UW Tacoma, Team 1-2, Rose Winter 2016人のメンバー
UWT-ROSE-W16S1G2
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 17
今までの合計 370
