メインコンテンツにスキップ
Bissell Zing 2156A Cord Retraction Mechanism Replacement
必要な工具と部品
  1. Bissell Zing 2156A Cord Retraction Mechanism Replacement, Rear Wheel: 手順 1、 1の画像 1
    • Remove the dust tank, so the vacuum can lie upside down easily.
    • Press the grey button while pulling up.
  2. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 2、 1の画像 1
    • Flip the vacuum upside down.
  3. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 3、 3の画像 1 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 3、 3の画像 2 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 3、 3の画像 3
    • Place your hand inside between the wheel and vacuum and pry the wheel off.
    • Repeat with the other side.
  4. Bissell Zing 2156A Cord Retraction Mechanism Replacement, Case: 手順 4、 2の画像 1 Bissell Zing 2156A Cord Retraction Mechanism Replacement, Case: 手順 4、 2の画像 2
    • Remove the two 18.1 mm screws using a Phillips #0 screwdriver.
    • Remove the four 18.1 mm screws under the wheels using a Phillips #0 screwdriver.
    • Don't try this until you have removed the wheels!
  5. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 5、 3の画像 1 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 5、 3の画像 2 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 5、 3の画像 3
    • Use the spudger to loosen the top case from the bottom. Make sure to loosen it all around the bottom and lift up.
  6. Bissell Zing 2156A Cord Retraction Mechanism Replacement, Cord Retraction Mechanism: 手順 6、 2の画像 1 Bissell Zing 2156A Cord Retraction Mechanism Replacement, Cord Retraction Mechanism: 手順 6、 2の画像 2
    • The spring only needs replacing if the arm is loose!
    • Remove the 20mm spring and replace it with a working spring.
    • Press down the spring, angle it away from the lever arm, and then pull out the spring.
  7. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 7、 2の画像 1 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 7、 2の画像 2
    • Pull on the body to let the mechanism's pin move.
    • Pull the mechanism out.
    • Be careful of the red and black wires, as they can get snagged on the casing!
  8. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 8、 2の画像 1 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 8、 2の画像 2
    • Tension the part by holding the stationary mechanism and rotating the wheel counterclockwise.
    • When the retraction mechanism is tensioned, it should be wound up, not flat.
    • Fully retract the cord before reinserting it, so you keep every bit of tension available.
  9. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 9、 3の画像 1 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 9、 3の画像 2 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 手順 9、 3の画像 3
    • This step is only needed if fully removing the cord retraction mechanism. If the cord doesn't need to come out, this cowling can stay untouched.
    • Use a spudger to pop the clips out of the cowling's outside face. Pull it out.
    • Remove the holders on the inside of the cowling so the bracket can be pivoted out.
    • Separate the cowling and bracket and remove the cord.
    • Keep track of the small bracket; if it's lost the part won't go in right.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Emma R
メンバー登録日: 02/14/24
498 ポイント
3のガイドは作成済み
チーム
University of Memphis, Team 3-4, Sneed Spring 2024 University of Memphis, Team 3-4, Sneed Spring 2024人のメンバー
UM-SNEED-S24S3G4
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 65
今までの合計 1,027
