はじめに
Is your Bissell SpotClean ProHeat 5207U not spraying water? It could be because of a failing water pump. Follow this guide to replace the water pump for your Bissell SpotClean ProHeat 5207U.
必要な工具と部品
Remove the marked 19.7 mm screws on the underside of the device using the Phillips #00 screwdriver.
もう少しです!
終わりに
2 の人々がこのガイドを完成させました。
