はじめに
Is the water tank on your Bissell SpotClean ProHeat 5207U leaking? It could be because of a failing float gasket. Follow this guide to replace the float gasket on your Bissell SpotClean ProHeat 5207U .
必要な工具と部品
Position the device so that you can see the text at the bottom saying "SpotClean ProHeat."
Remove the dirty water tank located to the right.
もう少しです!
終わりに
3 の人々がこのガイドを完成させました。
