メインコンテンツにスキップ
Bissell SpotBot Pet Repair Brush Motor Replacement
必要な工具と部品
  1. Bissell SpotBot Pet Repair Brush Motor Replacement, Brush Motor: 手順 1、 1の画像 1
    • First, set your Bissell SpotBot Pet on a flat surface to begin your repair.
  2. Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 2、 1の画像 1
    • Lift the right container vertically to remove it from the vacuum.
  3. Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 3、 2の画像 1 Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 3、 2の画像 2
    • Gently lift up the tab on the top of the vacuum and then proceed to lift the left container straight up to release it.
  4. Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 4、 1の画像 1
    • Remove the tube from the vacuum by sliding the tube out of its holder on the side.
  5. Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 5、 2の画像 1 Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 5、 2の画像 2
    • Unscrew the 4 screws on the top of the device and gently lift the top half up.
    • A ribbon cable is still attached to the underside of the top half.
  6. Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 6、 3の画像 1 Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 6、 3の画像 2 Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 6、 3の画像 3
    • Unplug the ribbon cable that connects the bottom half to the control panel on the top half. Then, set the top half off to the side.
  7. Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 7、 2の画像 1 Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 7、 2の画像 2
    • Unscrew the screw next to the white plastic wiring harness box. This will then allow you to set the white box off to the side.
  8. Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 8、 1の画像 1
    • Unscrew the screws on the plastic holder on the right side of the device. Once this is done, remove the plastic holder from the vacuum.
    • Unscrew the screws that mount the vacuum motor to the device as shown.
  9. Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 9、 2の画像 1 Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 9、 2の画像 2
    • Unplug the wires by disconnecting the section that connects the motor to the wiring harness.
  10. Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 10、 2の画像 1 Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 10、 2の画像 2
    • Lift the white suction motor from the right side of the device. Lift it straight up and set it off to the side of the vacuum.
  11. Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 11、 2の画像 1 Bissell SpotBot Pet Repair Brush Motor Replacement: 手順 11、 2の画像 2
    • Unscrew the screws for the brush motor as shown, this motor controls the automatic scrubbing mechanism.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Anthony Bonvino
メンバー登録日: 09/26/17
437 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S7-G3, Banghart Fall 2017 Cal Poly, Team S7-G3, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S7G3
4 メンバー
4のガイドは作成済み
コメント 1 件
hi i think you did an amazing job of breaking down how to disasemble this spotbot. i have the exact same one and though it works great suction is amazing, the brushes dont spin and i took it apart completely except i didnt know where the motor was that controlled the brushes until reading this. thanks so much
art - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 1,433
