メインコンテンツにスキップ
Bissell SmartClean 1605 Roller Brush Replacement
必要な工具と部品
  1. Bissell SmartClean 1605 Roller Brush Replacement, Roller Brush: 手順 1、 1の画像 1
    • Make sure your device is powered off.
  2. Bissell SmartClean 1605 Roller Brush Replacement: 手順 2、 1の画像 1
    • Gently flip device over.
  3. Bissell SmartClean 1605 Roller Brush Replacement: 手順 3、 3の画像 1 Bissell SmartClean 1605 Roller Brush Replacement: 手順 3、 3の画像 2 Bissell SmartClean 1605 Roller Brush Replacement: 手順 3、 3の画像 3
    • Remove plastic plate cover to reveal brush roller.
  4. Bissell SmartClean 1605 Roller Brush Replacement: 手順 4、 2の画像 1 Bissell SmartClean 1605 Roller Brush Replacement: 手順 4、 2の画像 2
    • Remove brush roller from its slots on either side.
    • Apply pressure to one side and pull the roller out of its opposite slot.
    • It's like taking out a spring loaded toilet paper holder.
終わりに
作成者
3人の作成者と共同で作成されました。
Austin Maranville
メンバー登録日: 09/26/17
117 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S7-G4, Banghart Fall 2017 Cal Poly, Team S7-G4, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S7G4
5 メンバー
5のガイドは作成済み
13 件のコメント
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
Brian - 返信
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
Ryan Beaudre - 返信
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
Geoffrey Fraser - 返信
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
Mazinger Z - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 13
今までの合計 1,028
