メインコンテンツにスキップ
Bissell Pet Hair Eraser Motherboard Replacement
必要な工具と部品
  1. Bissell Pet Hair Eraser Motherboard Replacement, Dirt Cup: 手順 1、 2の画像 1 Bissell Pet Hair Eraser Motherboard Replacement, Dirt Cup: 手順 1、 2の画像 2
    • Firmly grasp the handle and press the release button.
    • Gently pull the dirt cup down and away from the vacuum body.
  2. Bissell Pet Hair Eraser Motherboard Replacement, Power Button: 手順 2、 2の画像 1 Bissell Pet Hair Eraser Motherboard Replacement, Power Button: 手順 2、 2の画像 2
    • Remove the six 1.2 mm Philips #2 screws from the handle and base.
  3. Bissell Pet Hair Eraser Motherboard Replacement: 手順 3、 2の画像 1 Bissell Pet Hair Eraser Motherboard Replacement: 手順 3、 2の画像 2
    • Grasp each half of the body and gently pull apart.
    • The green handle, power button, charge light lens, and dirt cup release are not fastened in place.
    • Once the case is split apart these items may come dislodged.
  4. Bissell Pet Hair Eraser Motherboard Replacement: 手順 4、 3の画像 1 Bissell Pet Hair Eraser Motherboard Replacement: 手順 4、 3の画像 2 Bissell Pet Hair Eraser Motherboard Replacement: 手順 4、 3の画像 3
    • The power button can be removed by gently lifting it off the circuitry.
  5. Bissell Pet Hair Eraser Motherboard Replacement, Motherboard: 手順 5、 2の画像 1 Bissell Pet Hair Eraser Motherboard Replacement, Motherboard: 手順 5、 2の画像 2
    • Remove the battery plastic hold down by lifting it off the tabs.
    • Remove the battery by lifting straight up.
    • Position the battery aside.
  6. Bissell Pet Hair Eraser Motherboard Replacement: 手順 6、 3の画像 1 Bissell Pet Hair Eraser Motherboard Replacement: 手順 6、 3の画像 2 Bissell Pet Hair Eraser Motherboard Replacement: 手順 6、 3の画像 3
    • Grasp the charger port and remove it by lifting it straight out of the case.
    • Set the charger port next to the battery.
  7. Bissell Pet Hair Eraser Motherboard Replacement: 手順 7、 2の画像 1 Bissell Pet Hair Eraser Motherboard Replacement: 手順 7、 2の画像 2
    • Remove the power button and charge LED light by gently pulling straight out of the case.
    • The vacuum motor can be removed by pulling straight out of the case.
    • All internals are now removed.
    • Set the case halves aside.
  8. Bissell Pet Hair Eraser Motherboard Replacement: 手順 8、 1の画像 1
    • Remove the two 1 mm Phillips #2 screws in the shown locations.
  9. Bissell Pet Hair Eraser Motherboard Replacement: 手順 9、 2の画像 1 Bissell Pet Hair Eraser Motherboard Replacement: 手順 9、 2の画像 2
    • Disconnect the power leads from the vacuum motor.
    • The red power lead goes on the terminal with the visible red dot.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jim Lopez
メンバー登録日: 09/20/18
586 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 8
今までの合計 388
