この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Do you have a Bionaire mini tower fan that appears to not be working? It may be due in part to the fan blades spinning the wrong way, which is a very simple fix. If you need to instead replace the fan blades as a whole, just follow the steps that are listed here.
必要な工具と部品
There are 6 screws holding the entire fan together, which need to be removed to access the internals of the fan.
3 の人々がこのガイドを完成させました。
