メインコンテンツにスキップ
Bionaire Mini Tower Fan Blade Replacement
必要な工具と部品
  1. Bionaire Mini Tower Fan Blade Replacement, Blades: 手順 1、 2の画像 1 Bionaire Mini Tower Fan Blade Replacement, Blades: 手順 1、 2の画像 2
    • There are 6 screws holding the entire fan together, which need to be removed to access the internals of the fan.
  2. Bionaire Mini Tower Fan Blade Replacement: 手順 2、 1の画像 1
    • Once the screws are all off, the fan can be pulled apart with a little bit of force. However, not too much force is required.
  3. Bionaire Mini Tower Fan Blade Replacement: 手順 3、 3の画像 1 Bionaire Mini Tower Fan Blade Replacement: 手順 3、 3の画像 2 Bionaire Mini Tower Fan Blade Replacement: 手順 3、 3の画像 3
    • Once you have the fan apart, in order to get more maneuverability, the wire attached to the motor needs to be loosened. This can be done by removing the two screws highlighted in red.
  4. Bionaire Mini Tower Fan Blade Replacement: 手順 4、 2の画像 1 Bionaire Mini Tower Fan Blade Replacement: 手順 4、 2の画像 2
    • To get more maneuverability, remove the button panel. This can be done by removing the 2 screws on either side of the panel in order to fully remove it.
  5. Bionaire Mini Tower Fan Blade Replacement: 手順 5、 2の画像 1 Bionaire Mini Tower Fan Blade Replacement: 手順 5、 2の画像 2
    • Carefully remove the panel by pulling on it. It should fall out easily and separate completely from its housing.
  6. Bionaire Mini Tower Fan Blade Replacement: 手順 6、 2の画像 1 Bionaire Mini Tower Fan Blade Replacement: 手順 6、 2の画像 2
    • The bolt that you need to remove is inside of the pre-installed fan blades. With your pliers, grab a hold of the nut and twist to the RIGHT. This will allow you to remove the fan blades.
  7. Bionaire Mini Tower Fan Blade Replacement: 手順 7、 3の画像 1 Bionaire Mini Tower Fan Blade Replacement: 手順 7、 3の画像 2 Bionaire Mini Tower Fan Blade Replacement: 手順 7、 3の画像 3
    • In order to install the new blades, there are two pieces that you have to match up. The blades and pole both have a flat side that you have to match up in order for the blades to stay on.
    • Make sure when you install the blades, it blows air when it rotates in a counterclockwise fashion.
  8. Bionaire Mini Tower Fan Blade Replacement: 手順 8、 1の画像 1
    • Tighten the bolt to the left and you have successfully installed your new fan blades.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Kyle Taggard
メンバー登録日: 09/29/15
218 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015人のメンバー
CPSU-GREEN-F15S14G4
5 メンバー
16のガイドは作成済み
コメント 1 件
Thank you the instructions were spot on
Jason Mendez - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 39
今までの合計 3,762
