メインコンテンツにスキップ
Bicycle Handlebar Tape Replacement
必要な工具と部品
  1. Bicycle Handlebar Tape Replacement, Handlebar Tape: 手順 1、 3の画像 1 Bicycle Handlebar Tape Replacement, Handlebar Tape: 手順 1、 3の画像 2 Bicycle Handlebar Tape Replacement, Handlebar Tape: 手順 1、 3の画像 3
    • Undo the brake cables holding the brake calipers under tension.
    • Depress the brake/shift levers (brifters) and insert a 5mm Allen key into the internal bolt. This bolt secures the brifters to the handlebar.
    • With the 5mm Allen key, loosen and temporarily remove brifters.
  2. Bicycle Handlebar Tape Replacement: 手順 2、 3の画像 1 Bicycle Handlebar Tape Replacement: 手順 2、 3の画像 2 Bicycle Handlebar Tape Replacement: 手順 2、 3の画像 3
    • Remove the old tape and discard.
    • Pour some rubbing alcohol on the rag and clean any old adhesive residue off the handlebar.
  3. Bicycle Handlebar Tape Replacement: 手順 3、 3の画像 1 Bicycle Handlebar Tape Replacement: 手順 3、 3の画像 2 Bicycle Handlebar Tape Replacement: 手順 3、 3の画像 3
    • Starting on the right side of the handlebar, wrap the new tape around the end in a clockwise direction moving inward.
    • Be sure to wrap the tape tight, but don't pull so hard that it rips!
    • Using the scissors, cut the tape at an angle towards the outside of the bar.
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured here)
  4. Bicycle Handlebar Tape Replacement: 手順 4、 3の画像 1 Bicycle Handlebar Tape Replacement: 手順 4、 3の画像 2 Bicycle Handlebar Tape Replacement: 手順 4、 3の画像 3
    • On the left side of the handlebar, wrap the tape around the end in a counter-clockwise direction moving inward.
    • Wrap tight, but don't rip!
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured).
  5. Bicycle Handlebar Tape Replacement: 手順 5、 2の画像 1 Bicycle Handlebar Tape Replacement: 手順 5、 2の画像 2
    • Using the 5mm Allen key, reattach and tighten the brifter levers onto the handlebar.
  6. Bicycle Handlebar Tape Replacement: 手順 6、 2の画像 1 Bicycle Handlebar Tape Replacement: 手順 6、 2の画像 2
    • Reattach the brake cables to the brifters and brake calipers
    • Depress the brake levers a couple of times to test and confirm that the cables were reinstalled properly before riding.
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Jordan Byrnes
メンバー登録日: 05/05/17
132 ポイント
1ガイドが承認済み
チーム
UC Davis, Team S1-G70, Coad Spring 2017 UC Davis, Team S1-G70, Coad Spring 2017人のメンバー
UCD-COAD-S17S1G70
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 612
