メインコンテンツにスキップ
Betty Crocker Hot Pot BC-1762 Disassembly
必要な工具と部品
  1. Betty Crocker Hot Pot BC-1762 Disassembly, Betty Crocker Hot Pot BC-1762 Disassembly: 手順 1、 2の画像 1 Betty Crocker Hot Pot BC-1762 Disassembly, Betty Crocker Hot Pot BC-1762 Disassembly: 手順 1、 2の画像 2
    • Use the Phillips #1 screwdriver to remove the main 24 mm screw, washer, and black stopper located at the bottom of the Hot Pot.
  2. Betty Crocker Hot Pot BC-1762 Disassembly: 手順 2、 2の画像 1 Betty Crocker Hot Pot BC-1762 Disassembly: 手順 2、 2の画像 2
    • Pop off the dial that controls the heat setting.
  3. Betty Crocker Hot Pot BC-1762 Disassembly: 手順 3、 1の画像 1
    • Remove the bottom section by sliding the dial bar backwards and out.
  4. Betty Crocker Hot Pot BC-1762 Disassembly: 手順 4、 2の画像 1 Betty Crocker Hot Pot BC-1762 Disassembly: 手順 4、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the two 13 mm screws and small metal bar that hold the two thick white wires in place.
    • These two wires combine to connect to the power cord on the outside of the device.
  5. Betty Crocker Hot Pot BC-1762 Disassembly: 手順 5、 2の画像 1 Betty Crocker Hot Pot BC-1762 Disassembly: 手順 5、 2の画像 2
    • Use the Phillips #1 screwdriver to remove:
    • the transparent red block
    • 11 mm screw and small washer
  6. Betty Crocker Hot Pot BC-1762 Disassembly: 手順 6、 1の画像 1
    • Detach the raised metal portion by removing the 15 mm screw and washer using a Phillips #1 screwdriver.
  7. Betty Crocker Hot Pot BC-1762 Disassembly: 手順 7、 3の画像 1 Betty Crocker Hot Pot BC-1762 Disassembly: 手順 7、 3の画像 2 Betty Crocker Hot Pot BC-1762 Disassembly: 手順 7、 3の画像 3
    • Use the Phillips #1 screwdriver to remove the four 10 mm screws and washers that hold the cross section of metal in place.
  8. Betty Crocker Hot Pot BC-1762 Disassembly: 手順 8、 3の画像 1 Betty Crocker Hot Pot BC-1762 Disassembly: 手順 8、 3の画像 2 Betty Crocker Hot Pot BC-1762 Disassembly: 手順 8、 3の画像 3
    • Remove the last 10 mm screw and thin metal bar that are located under where the large metal plate was (put your back into it).
  9. Betty Crocker Hot Pot BC-1762 Disassembly: 手順 9、 1の画像 1
    • Device Schematic
終わりに
作成者
2人の作成者と共同で作成されました。
Aoife O'Reilly
メンバー登録日: 09/14/22
219 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 14
今までの合計 225
