メインコンテンツにスキップ
Bernina 350 PE L-Board D5 Capacitor Replacement
必要な工具と部品
  1. Bernina 350 PE L-Board D5 Capacitor Replacement, Loosen and Remove L-Board Screw: 手順 1、 3の画像 1 Bernina 350 PE L-Board D5 Capacitor Replacement, Loosen and Remove L-Board Screw: 手順 1、 3の画像 2 Bernina 350 PE L-Board D5 Capacitor Replacement, Loosen and Remove L-Board Screw: 手順 1、 3の画像 3
    • Remove the sewing machine's L-Board by removing this screw with a Torx T-20 driver.
  2. Bernina 350 PE L-Board D5 Capacitor Replacement, Detach L-Board Cable and Remove L-Board: 手順 2、 3の画像 1 Bernina 350 PE L-Board D5 Capacitor Replacement, Detach L-Board Cable and Remove L-Board: 手順 2、 3の画像 2 Bernina 350 PE L-Board D5 Capacitor Replacement, Detach L-Board Cable and Remove L-Board: 手順 2、 3の画像 3
    • Place fingers above and beyond Bear Quilting Patch and pull l-board gently toward you.
    • Rotate left side of l-board toward you and to the right to access cable.
    • Gently remove yellow cable.
  3. Bernina 350 PE L-Board D5 Capacitor Replacement, Remove L-Board's Cover: 手順 3、 2の画像 1 Bernina 350 PE L-Board D5 Capacitor Replacement, Remove L-Board's Cover: 手順 3、 2の画像 2
    • Remove 4 screws with Torx T-10 driver.
    • Foreground is the base, pull it toward you and cover (background/closest to table) stays behind.
    • Base, with l-board attached, is shown in last picture.
  4. Bernina 350 PE L-Board D5 Capacitor Replacement, Examine L-Board Capacitors: 手順 4、 3の画像 1 Bernina 350 PE L-Board D5 Capacitor Replacement, Examine L-Board Capacitors: 手順 4、 3の画像 2 Bernina 350 PE L-Board D5 Capacitor Replacement, Examine L-Board Capacitors: 手順 4、 3の画像 3
    • Capacitor attached to D5 is bulging out the top and is pushing its innards out the bottom.
    • If damaged like the one in photograph, obtain a replacement capacitor for D5 that is rated for long-life, 25 volts, and 100 µF, I found one at MicroCenter for $0.99.
  5. この手順で使用する道具:
    • I used a soldering gun to wick and to remove as much solder from back side of board where D5 is marked.
    • After solder is removed, I gently bent the capacitors pins so they were straightened and ready to remove from hole.
    • Add flux to the board, heat the capacitor's pins, and use a tweezers to pull on the D5 capacitor.
  6. Bernina 350 PE L-Board D5 Capacitor Replacement, Install Replacement Capacitor: 手順 6、 3の画像 1 Bernina 350 PE L-Board D5 Capacitor Replacement, Install Replacement Capacitor: 手順 6、 3の画像 2 Bernina 350 PE L-Board D5 Capacitor Replacement, Install Replacement Capacitor: 手順 6、 3の画像 3
    • Slide the replacement capacitor into the D5 board holes.
    • Heat the board and apply solder.
    • Replacement capacitor looks like pictures to the left.
  7. Bernina 350 PE L-Board D5 Capacitor Replacement: 手順 7、 1の画像 1
    • Replace cover on l-board and reinsert 4 screws.
    • Gently place extra slack from yellow l-board cable back inside sewing machine body.
    • In reverse, return to Step 2, complete, and conclude with Step 1 to continue reassembling sewing machine and test.
終わりに
To reassemble your device, follow these instructions in reverse order beginning with Step 2.
作成者
2人の作成者と共同で作成されました。
NorthernBigDummy
メンバー登録日: 08/25/15
622 ポイント
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 340
