メインコンテンツにスキップ
Bem Wireless HL2739B Speaker Motherboard Replacement
必要な工具と部品
  1. Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Battery: 手順 1、 1の画像 1
    • Peel the rubber cover back from the corner of the speaker to reveal the screw.
    • Repeat for the three remaining corners.
  2. Bem Wireless HL2739B  Speaker Motherboard Replacement: 手順 2、 3の画像 1 Bem Wireless HL2739B  Speaker Motherboard Replacement: 手順 2、 3の画像 2 Bem Wireless HL2739B  Speaker Motherboard Replacement: 手順 2、 3の画像 3
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
  3. Bem Wireless HL2739B  Speaker Motherboard Replacement: 手順 3、 1の画像 1
    この手順で使用する道具:
    購入する
    • Lift the bottom cover away from the rest of the speaker.
    • There are wires connecting the battery and cover to the rest of the speaker. Be careful when removing the base cover.
    • Using the tweezers, pull the wires from the speaker's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the speaker after this step.
  4. Bem Wireless HL2739B  Speaker Motherboard Replacement: 手順 4、 1の画像 1
    • Using a plastic opening tool, gently pry the battery from the metal base.
  5. Bem Wireless HL2739B  Speaker Motherboard Replacement: 手順 5、 1の画像 1
    • Using tweezers, pull the wires from the metal base connection.
  6. Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Motherboard: 手順 6、 2の画像 1 Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Motherboard: 手順 6、 2の画像 2
    • Unscrew the four 10mm screws from the motherboard.
  7. Bem Wireless HL2739B  Speaker Motherboard Replacement: 手順 7、 2の画像 1 Bem Wireless HL2739B  Speaker Motherboard Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using tweezers, remove the blue/white and red/black wires from motherboard.
  8. Bem Wireless HL2739B  Speaker Motherboard Replacement: 手順 8、 2の画像 1 Bem Wireless HL2739B  Speaker Motherboard Replacement: 手順 8、 2の画像 2
    • Gently re-position the motherboard so you can access the bus wire connected to the speaker.
    • Remove bus wire from the speaker and lift out the motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ryan McQueeney
メンバー登録日: 02/28/17
446 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S2-G4, Nance Spring 2017 USF Tampa, Team S2-G4, Nance Spring 2017人のメンバー
USFT-NANCE-S17S2G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 917
