はじめに
This guide shows how to completely disassemble the Bella KitchenSmith 2 Slice Toaster 12082. Before beginning the disassembly, make sure that your toaster is not plugged into the wall - you don’t want to get electrocuted while you’re doing your disassembly. While you are doing the disassembly make sure to treat your toaster with respect - the toaster contains a circuit board which could be damaged if you are not careful.
必要な工具と部品
Remove the toaster's handle by firmly grasping it and pulling on it away from the device.
2 の人々がこのガイドを完成させました。
