メインコンテンツにスキップ
Bella KitchenSmith 2 Slice Toaster 12082 Disassembly
必要な工具と部品
  1. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly, Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 1、 1の画像 1
    • Remove the toaster's handle by firmly grasping it and pulling on it away from the device.
    • This may take a bit of effort - do not worry about pulling too hard - you will not break the toaster.
  2. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 2、 1の画像 1
    この手順で使用する道具:
    購入する
    • Turn the toaster over. Remove the two rubber gaskets from the legs of the toaster using a pointed tool such as tweezers.
  3. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 3、 2の画像 1 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 3、 2の画像 2
    • Using the Triangle #2 screwdriver, remove four 100.0 mm screws from the base of the toaster.
  4. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 4、 1の画像 1
    • Lift off the plastic cover.
    • You may feel a little resistance from the connection between the control knob and its counterpart on the circuit panel but just wiggle the cover around a bit and pull up and the cover should come off.
  5. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 5、 2の画像 1 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 5、 2の画像 2
    • Unfold the four tabs that hold on the top cover to the toaster
    • In the next few steps you will be unfolding a lot of the metal tabs - you can either use your hand or the metal spudger to do so
    • Many of the metal tabs are very fragile - be very careful when you unfold them or they will break!
  6. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 6、 1の画像 1
    • Unfold the tab above the toaster's handle.
  7. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 7、 1の画像 1
    • Pull the metal rod that was under the tab up and away from the device.
    • You may feel a bit of resistance as you pull the rod up - just wiggle it around a bit as you pull up and the rod should come free.
  8. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 8、 2の画像 1 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 8、 2の画像 2
    • Remove the spring from the front of the toaster.
  9. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 9、 2の画像 1 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 9、 2の画像 2
    • Unfold the two tabs on the back of the toaster.
  10. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 10、 1の画像 1
    • Remove the bread holder base from the toaster by lifting it up and then pulling it towards you.
  11. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 11、 2の画像 1 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 11、 2の画像 2
    • Remove the spring part of the bread holding mechanism.
  12. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 12、 1の画像 1
    • Unfold the two tabs on the top of the toaster that hold the central bar in place.
  13. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 13、 2の画像 1 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 13、 2の画像 2
    • Remove the central bar.
  14. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 14、 2の画像 1 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 14、 2の画像 2
    • Undo the latch to the breadcrumb tray and swing the tray open.
  15. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 15、 1の画像 1
    • Unfold the two tabs that hold the breadcrumb tray in place.
  16. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 16、 2の画像 1 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 16、 2の画像 2
    • Lay the tray back down to its resting position and then pull the tray up and away from the device.
  17. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 17、 2の画像 1 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 17、 2の画像 2
    • Unfold the twelve tabs that hold both sides of the toaster in place.
  18. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 18、 2の画像 1 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 18、 2の画像 2
    • Pull the bottom of the side panels out and over the inner toaster pieces that are holding them in place.
    • Then completely remove both side panels.
  19. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 19、 2の画像 1 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 19、 2の画像 2
    • Using the Phillips #1 screwdriver, remove the two 8.0 mm screws from the backside of the toaster.
  20. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 20、 1の画像 1
    • Undo the two tabs on the backside of the toaster.
  21. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 21、 1の画像 1
    • Slightly pull the back panel of the toaster away from the device.
    • Do not try to attempt to completely remove the back panel - there are wires attached to the back panel that are still attached to the main body of the toaster - any attempt to completely remove the back panel could result in breaking your toaster!
  22. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 22、 1の画像 1
    • Remove the bread holders from the device.
    • When you pull back the back panel, the bread holders will fall out.
    • The bread holders were positioned so that their tips were pointed out towards the edges of the toaster slots.
  23. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: 手順 23、 1の画像 1
    • Once you've taken the toaster apart you can get a very good sense of how it operates. Here's the basics of how it works:
    • There is always power running to the toaster when it is plugged in but the electrical circuit is broken until the handle is pressed down. When the handle is pressed down, two switches are closed, closing the circuit and turning on the power to the toaster.
    • When the power goes on, an electromagnet in the circuit board is turned on, causing a magnet on the toasters handle to bond to the electromagnet and holding the handle down (and keeping the toaster on) until the circuit is broken.
    • The circuit is broken when a predetermined amount of power has entered the 555 timer chip in the circuit board - when enough power has entered the chip it sends a signal that causes the electromagnet to lose enough of its magnetic field that the handle is released and the bread pops.
    • The amount of power that flows to the chip is controlled by a potentiometer which is connected to the circular control knob.
    • If the maximum toasting setting of seven is used, the potentiometer only allows a small amount of the power to flow into the chip, causing it to take longer to reach the required threshold of power and making the bread spend a longer time in the toaster.
    • On the other hand, if the cancel setting is used, the potentiometer barely offers any resistance at all, allowing the power threshold in the chip to quickly be reached and as a result, rapidly triggering the popping of the toaster.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ethan Goldman
メンバー登録日: 09/16/21
441 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 44
今までの合計 1,216
