メインコンテンツにスキップ
Bella 4-Slice Toaster Oven Temperature Dial Replacement
必要な工具と部品
  1. Bella 4-Slice Toaster Oven Temperature Dial Replacement, Outer Shell: 手順 1、 1の画像 1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 2、 1の画像 1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 3、 1の画像 1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 4、 1の画像 1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 5、 1の画像 1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 6、 1の画像 1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 7、 1の画像 1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 8、 1の画像 1
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Temperature Dial Replacement, Temperature Dial: 手順 9、 1の画像 1
    • Using a plastic spudger, gently pry the black plastic temperature dial away from the face of the toaster.
  10. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 10、 1の画像 1
    • Remove two 5.91 mm #2 Phillips screws which secure the inner component to the toaster.
  11. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 11、 1の画像 1
    • Inside the device, unplug the red wire connecting the black plastic part of the dial to the heating element.
  12. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 12、 1の画像 1
    • Now unplug the other red wire from the black plastic part of the dial.
  13. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 13、 1の画像 1
    • Unplug the two white wires from the metal part of the dial.
  14. Bella 4-Slice Toaster Oven Temperature Dial Replacement: 手順 14、 1の画像 1
    • Remove the dial from device interior.
終わりに
作成者
3人の作成者と共同で作成されました。
Pierce Hampton
メンバー登録日: 01/31/19
561 ポイント
4のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 423
