メインコンテンツにスキップ
Bell and Howell DNV16HDZ Internal Screen Replacement
必要な工具と部品
  1. Bell and Howell DNV16HDZ Internal Screen Replacement, Lens Assembly: 手順 1、 2の画像 1 Bell and Howell DNV16HDZ Internal Screen Replacement, Lens Assembly: 手順 1、 2の画像 2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 2、 1の画像 1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 3、 1の画像 1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ Internal Screen Replacement, Internal Screen: 手順 4、 1の画像 1
    • Pull the side with the hand strap upwards to disconnect it from the camcorder.
  5. Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 5、 2の画像 1 Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 5、 2の画像 2
    • Remove the battery.
    • Remove the four 30 mm Phillips #0 screws on the back.
  6. Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 6、 3の画像 1 Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 6、 3の画像 2 Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 6、 3の画像 3
    • On the hinge of the camcorder remove the two 30 mm Phillips #0 screws.
    • Remove blue piece holding it together.
    • Remove the 50 mm Phillips #0 screw.
  7. Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 7、 2の画像 1 Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 7、 2の画像 2
    • Use the plastic opening tool and slowly pry open the side.
    • Now pull the part with camcorder out.
    • There is a wire connecting these two pieces using to much force will damage the camcorder.
  8. Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 8、 3の画像 1 Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 8、 3の画像 2 Bell and Howell DNV16HDZ Internal Screen Replacement: 手順 8、 3の画像 3
    • Have the screen open and twist it 90 degrees unscrew the 40 mm screw.
    • Repeat for the other side.
    • Use the plastic opening tool to pry the outer part of the screen, now attach the new one.
終わりに
作成者
2人の作成者と共同で作成されました。
Jerry Hadjah
メンバー登録日: 03/04/16
525 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 8-4, Botvin Spring 2016 UMass Dartmouth, Team 8-4, Botvin Spring 2016人のメンバー
UMASSD-BOTVIN-S16S8G4
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 329
